Memory Card Problem
  • Start date Start date
A
Android Question
Guest
I have a Prestigio Multipad Tablet PC PMP3370B. I had a 2 GB memory card and I recently brought a 8 GB memory card. Before in my 2 GB memory card there is used to be a lot of folders like youmniche, Android and other folders. But in this one there is only one folder called LOST.DIR.
What do I do ?
Hi
That is the only file which should be present on a new card. It's fine.
The other folders were created by the apps on your device which use the sd card.
Open each app which used your old card, change the storage settings to internal/phone and confirm. Then change the setting back to sd card (with the new card in your device) and the app should create the folders necessary ( empty folders). If you want to copy the contents of your old sd card to the new one the simplest way is via a card reader on your pc (save from old to pc and then copy to new card)
Hope this helps
Roger
