Memory card query?
swimming
Hi if i buy a tablet with 16gb internal storage,can i put a 32gb memory card in.and does this mean it allready has 16gb memory.
HIYA THIS IS WHATS IN THE DISCRIPTON
  • 10.1 inch screen.
  • LED backlit display with IPS technology.
  • Multi-touch screen.
  • Resolution 1280 x 800 pixels.
  • Support for simultaneous display of multiple languages.
  • Webcam.
  • 1GB RAM.
  • Android 4.1 operating system.
  • 1.6GHz ARM processor.
  • 16GB internal storage.
  • B/g/n wireless/WiFi enabled.
  • Bluetooth - enabling you to easily and wirelessly connect with other bluetooth enabled devices.
  • 3.5mm stereo headphone jack.
  • Built-in speaker.
  • Microphone.
  • 1 USB port.
THANKS SWEETY
Yes you can use a 32 or even 64 GB micro SD card. The 16 GB of internal storage will actually be around 12 GB, as the OS needs some space for itself to run. Remember, this is STORAGE, not RAM.
  • 1GB RAM.
  • 16GB internal storage. ...
In PC-terms, the '1GB ram' is the system memory. The '16GB internal storage' is the hard drive (c: drive if you like) and any SDCard you add is like adding another internal hard drive, or an external USB drive.
Dave
