Help Memory Card Slot Question
DrWeird
Hi all.
I have just took the plunge and swapped from my iPhone to a new X10.
I am loving android and all the features that go with it :)
The question I have is - on the memory card slot on the phone, can you still slide out the memory card even though it clicks in? I can do it on mine.
I push in the memory card and it clicks then I can still slide it out. Is it meant to do this?
Thanks!
DrW
Not sure - doesn't sound right but I haven't tried. I have removed the card by pressing it inward again first, then it slides back out.
Yeh don't worry about it, the click is the eject mechanism locking into place, not the card.
Press it in again until it clicks and it will eject the card a way so you can grab it and remove it safely.
