memory card what size
hi i have a galaxy ace, what size memory card will work with this phone - i have a 2gb sd card but need a bigger one - i have seen them up to 32GB but will these top end ones work on a galaxy ace
and what are the best make cards
many thanks
I suggest you max out at 16GB instead of 32GB. Some people who have used the max possible memory card have had problems. Class 4 should be ok for the usual storing of music/photos/backups etc
Speed Class Rating
The SD Association defines standard speed classes indicating minimum performance to record video. Both read and write speeds must exceed the specified value. These are defined in terms of suitability for different applications
  • Class 2 for SD video recording
  • Class 4 and 6 for high-definition video (HD) to Full HD video recording,
  • Class 10 for Full HD video recording and consecutive recording of HD stills
  • UHS Speed Class 1 for real-time broadcasts and large HD video files
The specification defines these classes in terms of performance curves that translate into the following minimum read-write performance levels on an empty card
Class Minimum performance
Class 2 2 MB/sec
Class 4 4 MB/sec
Class 6 6 MB/sec
Class 10 10 MB/sec
Speed Classes 2, 4, and 6 assert that the card supports the respective number of megabytes per second as a minimum sustained write speed for a card in a fragmented state. Class 10 asserts that the card supports 10 MB/s as a minimum non-fragmented sequential write speed.[41] By comparison, the older "
