memory card
  • Start date Start date
A
Android Question
Guest
are my pictures saved in the memory card to later move from memory card to computer? Or can I take the memory card to Walgreen's to save on a flash drive?
It depends on your phones settings - check your manual. Some default to saving pictures to the SD card, others to internal memory.
Either way you should be able to transfer the pictures to a computer of flash drive.
