Look for the guide to root your phone, so you can use apps2sd, but be warned rooting will void warranty. It is much simpler to do than it sounds.
Appart from that, just press the menu key (top left) goto settings, applications, manage applications, and delete apps you don't use, select the app name, then uninstall
i have the same disaster on my galaxy tab !!!
i'm getting 500+ business mail daily and can't keep even history for a week, it is saving all mails to phone memory !!! how to put mails on memory card !!!
