Memory Usage
Jethro10
Is there anywhere I can see a tutorial about how android uses internal memory and memory as program install space.
I've a milestone, but a friend has a Wildfire and seems to be able to install less stuff - saying its full.
I'm just curious to learn more.
also I have "corporate Calendar", pre-installed and running - I never use it, but it's running all the time, is there a way to disable pre-installed stuff you don't use?
Thanks
Jeff
