2fast4u88
To do a prl update or activate a phone you have to be non roaming (aka *228). Otherwise you have to call your carrier to activate the phone manually.
Also here is my guide for downgrading for froyo Windows Htc Merge Froyo Root, S-off & Sim unlock how-to • Guides • 2FastRoms There is a one click solution at the end of the thread on page 16 with non of the terminal commands needed.
Gingerbread guide is here Windows Htc Merge Gingerbread Root, Soff & Sim unlock how-to • Guides • 2FastRoms one click solution not yet done. Need a tester.
Turn s-off back on and other misc stuff here Htc Merge Return to Stock (s-on, cid, and simlock) • Guides • 2FastRoms Needs a bit off work to finish a full return to stock guide.
Verify s-off, super-cid and sim-lock here Verify the success of S-OFF, Super-CID & SIM-unlock • Guides • 2FastRoms
My rom based on the uscc gingerbread rom is here [ROM] Htc Merge xFuZiiOnZz-1.0.0 • Roms • 2FastRoms
Drell's kernel is here Undervolt & oc to 1.8ghz • Kernels • 2FastRoms
My kernel is here 2fast oc to 1.8 and undervolt • Kernels • 2FastRoms
Merge radio collection Htc Merge Official Radios • Radio's/Hboot's • 2FastRoms
My Clockworkmod recovery here Clockworkmod 5.0.2.3 • Recoverys • 2FastRoms
As for flashing the misc-image it isn't needed unless your carrier does ota or mms doesn't work. Which mms won't work on these carriers to name a few Alaska Communications, Appalachian Wireless, BlueGrass Cellular, Cellcom Wireless and nTelos. These carriers depend on strings in the misc image for mms to work. If you are on one of the carriers listed above or you have one that mms won't work on. Then you can restore the backup misc-image.
