YES and NO to the play lists, at least in 1.6. There is an app in the Market that allows you to retain your play lists. One you may try is called, "TuneSync". I have not tried it, but it should handle what you need. The other I have used and recommend, it is called, "doubleTwist"...
Good Luck
