Help Mesmorize ringtones/contacts
Welcome to the forums, biggr.
Contact app > (select contact) > menu > options > set ringtone
when i try to set a custom ringtone for a contact i select the contact and hit the menu button, but the only selections i get are "edit, delete, link contact, mark as default, and send namecard via..."
am i missing the options choice or what? or just doing this wrong
did you get your contacts from google mail. If you did then go into contacts. menu, you will see import and export. choose export to sd card. then import from sd card now you will have a G and a figure by the names use the figure now you can add a ringtone. this is what I did.. Good Luck
otherwise go contact > edit and scroll down to ringtone and choose phone ringtone. It SHOULD be for each individual contact by going that route
