Message tone
chukka63
when i go to settings,sound,default notification sounds,it also goes off if i get a facebook notification.
How do i seperate message notifications and facebook notifications?.
Go into the settings in your messaging app and set the notification sound from there. If you configure the notification sound from within the app, it will use those specific settings instead of the default settings. Then do the same with Facebook. Go into the Facebook settings and configure the notification sounds from within Facebook.
Thx,ive tried that and still facebook notifications are coming through so now ive unchecked all notification boxes and turned notifications to off.Just got to see if that will silence them
