Messaging
schdy37
When I begin to send a message and I select who I get multiple listings of the same contact. How do I delete the duplication?
Hi, if you go into "contacts", touch the three dots on the top right, and select "Settings", then "Contacts", second one down on the menu should be "Contacts to display", select this and choose from the list where the want the contacts to be displayed from, if all your contacts are on your Sim card select that, if you have "All contacts" selected it will show all copies of contacts wherever they are stored. Or you can choose "Customised list" and select from there. Phil
