Help Messed up platform.xml
koyax1111
I'm using a CAT B15Q running Android 4.4.2.
I've always had problems with internal storage since it was only around 1GB, and with the Android 4.4.2 you can't format your SD card as an internal storage or use it to store apps.
So I've looked up a few tutorials on how to bypass that problem. It involved rooting my phone, which I did using KingRoot. Then I was supposed to edit system/etc/permissions/platform.xml file and add some elements there. I did that but something apparently went wrong and I ended up losing the platform.xml file completely. I restarted my phone and the only thing I was able to do was call and send texts, every other app would crash. Then I thought that factory reset might solve the problem, so I did it. Now when I turn on my phone I get a black screen and a "Unfortunately, Setup Wizard has stopped" popup and the same for almost everything else ("Google text-to-speech has stopped", etc). When I click the OK button it just keeps reappearing, making my phone useless.
Any ideas how to fix this?
Thanks
