Met Launcher
Hi ardchoille. Thank you for using my App. And I also sorry about the bugs.
If you can review the context that the bug occurs i will feel thankful.
I appreciate all of your opinions.
I don't mind bugs, they're to be expected in new apps. I just want to report bugs so you can make the app better.
I tested Met Launcher on my htc Evo 4G (480x800 screen) running CyanogenMod 7.0.3.1. I love the idea of something different than the standard dockbar so I'm going to keep this app and hope that the below bugs can be fixed.
Bugs:
1. The icons in the ring are out of alignment - some icons overlap the ring while others are correctly aligned within the ring. I'm assuming there is a bug somewhere in the arc function?
2. I tapped the settings icon in the corner and tapped and dragged the ring to resize it - love this feature. I resized it to its largest size but the settings icon no longer does anything after that. It's still visible but does nothing when tapped. I had to uninstall and reinstall the app to get it back to the default size.
3. After resizing the ring to its largest size part of the ring was no longer visible.
I'm thinking all of these bugs are the result of how the ring arc is rendered on the screen, but I could be wrong.
What I liked:
1. Ring resize feature
2. Drag and drop icon sorting/adding/removal
3. Left/right hand use
4. Desktop dots to show which screen I am viewing
5. Trashcan inside the ring to remove icons from the home screen
Feature requests:
1. Allow the user to remove the home icon in the open app drawer. This should allow one more row of icons to reduce scrolling.
2. Allow the user to set a color for the ring to blend with a custom theme.
It's a great app and I look forward to seeing it grow :)
