I haven't used Metamorph since my OG Droid, but I did compile a couple tweak packages back then. All it is really doing is replacing images.
Knowing this, I would think that anything would work, unless specifically states not to use for certain Android versions.
I strongly suggest making a nandroid backup before using Metamorph. That way, if it doesn't work properly, you can revert to a stable state.
Kratos
Hi Kratos, I'm bit of a noob around here but I recently updated my galaxy S I9000 with Sephamore MixRomv6 running Jelly Bean 4.1.2 but when I had flashed a zImage onto my previous gingerbread 2.3.6 I was also given Clock Work Mod and a tweak package. obviously enough I no longer have the tweak package in this Rom but I was hoping you could point me in the right direction for a tweak package for Jelly Bean? I have already downloaded cpu tuner but dont want to F**k around with it too much!
thanks in advance!
