Root metamorph on2.1 rom theme control file not found
FUCCO
installed bbv7 works good. Trying to install a theme i had one my 2.0.1. i also tried to install the smokeless glass by pete. =In metamorph i keep getting the error "theme control file not found" and metamorph closes. Any way to get this fixed?
I could be way off base here but bbv7 is a 2.1 Rom and installing a 2.01 theme could cause alot of problems.
Make sure you're using his theme for the 2.1.
Does the zip file contain a file with extension .thm ? I think that's the theme control file it's talking about.
