Metro pcs huawei android[need help]!!!!
la420sss
my phone was working last night when i try to turn it on this morning the screen will not work but the metro pcs sound comes on and the lights work at the bottom i do not know what to do the screen does just not turn on
is there anyway to restart it without deleting my contacts?
Restarting the device won't delete your contacts _ What I would suggest you do if you are still having this problem is to remove and reinsert the battery after 10 minutes. This is called a soft reset. This usually fixes most problems unless there's something more serious happening with the device.
Good luck and welcome aboard. (:))
