Help Metro PCS system update
Why don't you all just uninstall System Update?..that will stop the phone from "updating" by itself and notifying you insistingly..I did it..nothing bad happened..
Can you post a screenshot of the about software info again? Did anything else changed besides software version?
@Xavier Black Could you take a look at this?
[I am still using stock] I have yet to see anyone post how to remove TWRP. I installed it using Flashify.
1. If U want to install the update, it seems that TWRP must be uninstalled/removed somehow.
a. I have yet to see anyone explain how to do this? If possible?
2. If U have TWRP installed, is it possible to use KDZ to update the phone?
EDIT: According to this, https://www.theandroidsoul.com/remove-twrp-recovery-restore-stock-recovery/, U can only remove TWRP by installing the original recovery for the phone. Is this possible? Does anyone know where to get the original recovery?
That's the original TouchWiz so you can get rid of the twrp..
I downloaded the zip and opened it in Windows Explorer. [I have SuperSU v2.82 installed if that matters]. How does this zip help me?
1. Can U elaborate a bit more about TouchWiz? [as it pertains to my issue]
2. Is TouchWiz installable via Google Play as with other apps?
3. I saw some articles about TouchWiz and Samsung. Does it apply to LG phones too?
That one is the one which gave me the TouchWiz..
Ok, 2 stupid questions.
I have been updating SuperSU for quite some time now on my LG.
1. I would have updated to this version at some point?
a. And, if so, I would already have TouchWiz installed on my LG and never been aware of this?
b. And, if so, how could I verify this?
2. If not, does this zip file have to be flashed in order to install v2.72? [and TouchWiz?]
