frosthax1 Android Enthusiast Jan 31, 2015 #2 You don't flash it that way you kdz it.look in the threads for going back kdz
LoopyD Android Enthusiast Feb 3, 2015 #4 Flashable zip perhaps? If anyone's got one help this guy out...
D Dastardly Muffin Member Feb 3, 2015 #5 If I'm correct with what you want to do refer to this http://androidforums.com/threads/br...is-might-work-for-you-too.833575/#post6471224 to revert to stock un-rooted. Then just re-root using towelroot or something else on the stock rom. It restores to 12b.
