Root [MetroPCS/CDMA] 32 or 64
averagewonder
Anyone know for sure if our S3 supports 64gb cards or just 32gb I hard that either the at&t or the Verizon supported the 32 but not the 64 for some reason
I just received a 64gig memory card from my girlfriend for Christmas. Had to format it to fat32 and is working perfectly. :D
Got the 64GB it's great..when i first got it unmounted and removed my 32..was saying it was damage for some reason and wouldn't mount or format for nothing..had to use my esteem to reformat it after that it's smooth sealing ..already down to 10 gigz mostly 720p movies 4-5 gig files gotta love it :D
64 works but u gotta format it to fat 32 format. and alot of people dont know that win 7 and win 8 don't give options to format it to that format anymore. i used a program called EaseUS Partition Master 9.1.1 Home Edition that should give u the option to format it to fat32 or else your phone wont be able to read/write to it. im sure there are other apps out there to do it with, but thats how i did mine.
If you want try the below suggestion
1. connect flash card to system.
2. go to device manager and select USB from Disk drives option.
3. Right click it and choose policies tab and set optimize for performance option.
4. close every thing and open command prompt
5. use format command: format *flash carddrivename* /FS:FAT32 /Q /X
I do this all day at work
Y'all know Linux code I know windows :)
Thats pretty neat good pointing out.
I have a friend that's a Windows coder, from way back in 3.1 days. He works in Redmond for MS.
Repartitioning with a FAT32 partition without LBA and formating with 32K allocation sizes fixes the problem also.
Format MicroSD under windows with FAT32 32K allocation sizes, command line with:
format X: /fs:fat32 /a:32K
