Root [MetroPCS/CDMA] a better system wipe program
1iwilly
Found this and wanted to share. please read carefully to understand what it does.
nice proggy to help when trying to do a clean install. not my work just sharing.
here is the link at XDA=http://forum.xda-developers.com/showthread.php?t=1983489
NOW don't download any files i'll post the correct one for our phone enjoy
Thanks for the upload. Works well with TWRP without no problem. Just read care fully when applying this on the custom recovery: Clockworkmod/TWRP. Good looking out for us here @ the android forum.
no it has nothing to do with this program cause every time i use triangle away to reset to zero before i found this program every time i did a reboot using quick boot it would register to the counter.
OK i found out one little detail. So when using this system wipe it is registering on the counter flash inside the download mode. I don't know if it does while using Clockworkmod like with TWRP. Now there is way to do the counter reset which shabbypanquin posted Here:http://androidforums.com/official-u...0m-return-stock-reset-your-flash-counter.html. If any matter this method can be used while using this zip fil. This is still a good system wipe file..Thanks
