Root [MetroPCS/CDMA] blocked freezing!
my samsung galaxy s3 crashes or gives cogelado sometimes and I have to remove the battery to use it again, this happens to me only with customs roms jelly beans jelly bean and even original ..
wanted saver if anyone knows a solution to this problem thanks in advance
mi samsung galaxy s3 se bloquea o se que da cogelado algunas veces y tengo que retirar la pila para poder usarlo de nuevo,esto me pasa solo con jelly beans customs roms e incluso con jelly bean original..
quisiera saver si alguien conoce alguna solucion a este problema de antemano gracias:D
make sure you follow these steps in installing roms
1.wipe -factory data reset
2.install rom
3.wipe cache/dalvik
4.reboot
