Shabbypenguin
Extreme Android User
Hey guys unlimitedammo tipped me off to having a custom splash screen is as easy as pie. normally it means including it in teh kernel and you are stuck with whatever i pick (hence my metropolis one im sure most of you remember
anyways this isnt my work or anything, just so happens the main guys script fails as we arent a supported device. ive requested he add support here hopefully he will add it on soon, but in teh mean time here is a modded version so you guys can play.
download modded version
go here for instructions
make sure to click thanks and show him your support
in case anyone wants it here is the one i made for my rom www.shabbypenguin.com/OUDstuff/Samsung/Metro/R530M/Metropolis/initlogo.rle
)anyways this isnt my work or anything, just so happens the main guys script fails as we arent a supported device. ive requested he add support here hopefully he will add it on soon, but in teh mean time here is a modded version so you guys can play.
