ManlyParasite
My data is not restoring using TWRP. I made a nand backup of blackbean, using the latest TWRP (3.3.2.0 I think)
I wanted to try LiquidSmooth, since it was 4.2
I liked it a little bit, but I decided to switch back to BB.
My internal card was moved to a 0 folder (thought that was fixed in 3.3.2.0) and my data (apps, app data, account info, etc) is not restoring. Something odd though, is that my saved wifi connections were restored, as well as my sms and mms messages. Right now, I'm downloading a file manager to see if there is anything in the /data folder.
EDIT: Scratch that, got the following message from Play Store:
Unknown error code during application install: "-24"
After the files are done transferring from the 0 folder to the root of the internal card, I'm going to try wiping data, then restoring the data from the nand backup.
EDIT: Sorry, I made a mistake, TWRP is 2.3.3.0, not what I said above.
I feel stupid for making this thread, if I had just held off a little bit, it wouldn't have been needed. Wiping the data then restoring worked. All my apps and everything are here again. Maybe this will help anybody else with a similar problem.
