Root [MetroPCS/CDMA] frequently contacted help.??
1iwilly
is there a way to remove the frequently contacted persons that show at the bottom when you are in the phone mode then favorites all the way at the bottom.??? thanks
While in the favorites section, tap menu button and there should be a option to clear frequent
when i click the menu button it dont give the options to clear frequent. add favorite, remove favorite and grid view and call setting only on my samsung galaxy note 2
