You can control Cerberus remotely through the website
www.cerberusapp.com or via SMS messages from another phone. The following commands are available (remember to replace *password* with your actual password, also remember that the password is case-sensitive):
cerberus password find (to locate your device)
cerberus password siminfo (to get SIM card info)
cerberus password wipe (to wipe your device memory)
cerberus password wipesd (to wipe the SD card)
cerberus password lock code (to lock your device with a password, replace *code* with the lock code you desire)
cerberus password unlock (to unlock your device)
cerberus password alarm text (to display a message and play a loud alarm, replace *text* with the message you want to be displayed)
cerberus password takepicture (to take a picture and send it to your email address, the front camera will be used if available)
cerberus password enabledata (to enable data access on your device)
cerberus password message text (to display a message, replace *text* with the message you want to be displayed)
cerberus password startemergency hours (to make the device send its location periodically, replace *hours* with the number of hours from one alert to the next)
cerberus password stopemergency (to stop emergency mode, the device will stop sending its location periodically)
cerberus password call number (to call a phone, replace *number* with the phone number you want to call, or don't write a number to make Cerberus call the sms sender)
cerberus password screenshot (to grab a screenshot and send it to your email address)
cerberus password enablewifi (to enable WiFi and automatically connect to open networks)
cerberus password capturevideo (to capture a video and send it to your email address)
cerberus password reboot (to reboot the device (works only on rooted devices))
cerberus password speak text (to make the device speak a message, replace *text* with the message you want to be spoken)
cerberus password enableroaming (to turn on data roaming)
