Root [MetroPCS/CDMA] I'm Zeroed out. )=
Could someone help me please? I don't know what to do. I flashed a bad illusion rom then Carbon but this happened.
Everything is on the attachment. I took a screenshot of my phone status.
Help would be appreciated!
Call Metropcs :) Tell them you're not getting any calls and text, they're gonna let you reprogram the phone, And after that, ALWAYS BACK UP YOUR NV.
http://androidforums.com/metropcs-g...very-important-backup-nv-before-flashing.html
Yeah my old sd card got corrupted.
That happened to me even when I went back to stock, the only thing that worked was 4g. I just switched it out with the warranty
How did you get it to fix? I have exact problem!!
thats a nv prob your best bet is to go back to stock and if its all still 0 perform a nv restore ofcourse assuming u backed up ur nv just like every1. if u didnt im sorry metro corp would be your last resort.
I made a backup but my old sd card got destroyed so i forgot to make a new one. D: I tried shabby return to stock. However, I got the phone back to stock but only data working but "Unknown prl, phone number" Even when I tried to manually update it with
1. In dialer enter *#22745927
2. Enable Hidden menu. Exit back to dialer
3. In dialer enter **772
4. Select Edit option in the NAM Info screen
5. Enter phone number in the MDN field.
6. Enter MIN in the MSID field.
7. Press back key. Select Done. Device will reset.
It still won't update my phone number. :s
no one said nv backup stores data in sd card....... it saves to a chip on your phone called nand so now that ur on stock download the app that pg shared with us on the thread. its on the first post.
never mind heres the app itself.
http://unleashedprepaids.com/upload/devs/playfulgod/misc/NVBackup&RestoreTool.apk
try just restoring DO NOT BACK UP!!! backing up will override your last saved nv data.
I did not know about this tool pretty handy could have helped me out when this happened then again even my nvrestore wasn't working lucky the stock helped me..
i posted it on the nv back up thread first post. pg was kind enough to share with us so i just updated it a while back on the op.
That flash counter was exactly what zeroed my info out in the first place lol at least the first version of it lol never again
lol you used the flash counter??? than yes you MUST ODIN back to lj1 (4.0.4) i promise it will fix you lol
This was a while ago.. few months back odin stock did the trick i ran it just to get back to stock to bring it to metro come to find out it fixed my issue
