nah i waited and i remember someone saying click on the 0 file till you get to the end but ive tried... i just found an external sd card in my room so ill just use that instead
if u installed the latest twrp they hid the internal so u have to select it in order for it to show. new features was being able to toggle either external,internal and even otg usb
if u select install just right below where it says Storage: Microsd card or whatever it says after "Storage:' press that then choose which storage location u want to work with once u make a selection press back on your phone and u should now be on internal or whatever storage u chose.
