Root [MetroPCS/CDMA] Liquidsmooth rom for d2mtr
That rom is garbage and doesn't work due to FC's in the 1st build, and that thread has been abandon. ;)
Thanks for sharing and hopefully it will come 2gether.
This one is new though, isn't it? Its 4.2.1 and the last one was still 4.1.2
Downloaded and will try it out now.
It actually looks like their trying it again.. its dated 1/3/13 ..... their first go was a disaster... maybe ill find some time go try it when I get a chance then again naw maybe not... :p loving touchwiz jb hahaha
I'll need some confirmed reports before trying. They didn't listen or acknowledge their problems before.
I tried it out!! Everything seems fine, no fc's but seems like data isn't working. I got 1x for a few seconds but after that nothing. Not too sure though. Other than that, really smooth.
Edit: Everyone, I'm sorry. Data IS working.:o
its their thread i was basing that off legmando33's review. i figured it would be best to post there so they would know.. if they bothered to read their thread this time
Judging by the last performance we will be asked to like their fb page and then they won't answer and the thread will be closed.
I kid, they should fix it shortly as other developers have adopted our carrier as well.
Very nice find actually! Its running fairly well. Data is working.
Screens:
Is anybody else having home button issues? for some reason when I click the home button it doesn't work. I even enabled the action bar at the bottom and when I click the home button on that it still doesnt work. I think I may have to reflash it.
Im very impress with this new build, and is way better than that 1st build they made back a month or so. :)
Glad to hear it :)
i have no personal issue with them just got irked that they clearly didnt care about user input last time. hopefully they keep on kicking out solid roms for yall and listen :)
Glad to hear it :)
I know what u mean it was the first rom I found when I got the phone... being an htc guy I thought I was doing something wrong until i started seeing post from other users... that was before I came across this enchanted metro s3 place of coarse.
Glad to hear it :)
Well said, the first build was ehhh, but they never took the time to find fixes for the things reported so i ditch it. But gave them another chance and seems good so far, but i know there are minor bugs. :)
Just downloaded it, been using blackbean as it seems the most optimal for me. Miss some touchwiz features, like a fully functioning s voice and the voice operated music player, but I didn't need them before the S3 and I don't need them now lol
Will get back and let you all know how it goes.
Also, make sure you download the 1 for d2mtr, that is the MetroPCS version. Other versions will likely cause many problems.
EDIT: Downloaded Beta 2, since that seemed like it was the 4.2 one, and I keep getting FC messages for setup wizard and gapps. Was that the wrong thing to download?
No that's good you just need to download the 4.2 gaps from from the link they provide. Instal the rom install the 4.2 gaps den you should be good to go.
