Root [MetroPCS/CDMA] Methods to improve data speeds?
hippiegang
Does snyone have any? I can hardly pull 1mbs in metro atlanta with full 4g signal....:banghead::banghead::banghead::banghead:
Go to settings, about phone, then status and post a screenshot so we can see your signal strength. Also do you have the unlimited plan cause those speeds look like you may be being throttled
That is better signal strength then I got and I get 5mbps all day weird. Only difference I see is mine says lte:13 and yours says lte:14
You have any friends with a 4g phone on metropcs? You would have to find out some other peoples speeds in the area to know if it is something with your account or just the area
have you flashed anything lately...try restoring a backup maybe...
if not go into root explorer and then get into the build.prop(its in the system folder)
open in text viewer and scroll all the way down until you see these entries
ro.ril.hsxpa=1
ro.ril.gprsclass=10
they should look just like that...if they are different then that might well be the problem
based on my experiments I would say something in the build.prop is changed either through a ROM or accidental editing with an app like build.prop editor
ro.ril.hsxpa=1
ro.ril.gprsclass=10
Just checked and its normal. Only thing I've done is flash liquid smooth.
ro.ril.hsxpa=1
ro.ril.gprsclass=10
Every thing looks good. Idk its prolly just metro pcs
