From the comments, it doesn't work for usc owners also. You can experiment with other mms apk and hope they work but it's doubtful.
If you can live without multiwindows I suggest JRom. It's just like morph but with working mms. Only bug I found on it was that wallpapers can't be set from settings. But you can still set it from your launcher.
Really I thought it was working for peolpe... I know it works on morph 1.1 but not 1.3 which is the multi windows one
I think that's just for long SMS split...
Can someone try this mms.apk to see if pictures and long text work I pull if from wezenhimier lite rom pictures and long text work for me when I was on it. http://db.tt/YgXdcKpk
Does wizenhiemer work for us? I haven't tried it yet and the thing about stock builds is they're too big to download unless I'm sure.I deleted my morph backup.Does wizenhiemer work for us? I haven't tried it yet and the thing about stock builds is they're too big to download unless I'm sure.
Yes it works I have tried both roms
So what helped u get mms working... I've tried like crazy and can't get it to work... Driving me nuts
Not to get off track here but since it's about morph ill add my 2 cents, anyone use it with tsf shell? My install doesn't like it at all, very weird things happen with the it, anytime the phone booted up it was stuck in landscape mode. the same for the stock touchwiz launcher, that crashed every time I tried to delete a screen, I installed apex an it seems to like that one. Nice rom but it wasn't meant for the metro s3... Might go back to black Bean.... But I'll miss multi view lol
I've played with Morph/4.2.1 cam/gallery app/multi-view combo for the last week and finally got mms and long sms working. Everything works.
The only bug I have left is the flashlight hesitates for a second when turning off/on, and sometimes wi-fi comes on by itself. (prolly a setting I haven't noticed/found yet... other issues around the house have kept me occupied)
Problem is, I haven't kept a good record of what mods I've made along the way to get everything working... I tried so many different things out of desperation, I lost track. lol
These are a few of the mods I made that I can remember off the top of my head;
Swap out the apn.config.xml file, lte apks and exchange usc files for the mtr files in buildprop (thanks to Shabby and Airtioteclint)
...and I replaced the feature.xml file edgeez posted here in post #518
... and I think I kicked it across the floor once or twice, spat, cursed, and spun in a tight circle three times while listening to the lead in "I" off Black Sabbath's Dehumanizer album (on 11 - not volume 10)... after that, everything worked.![]()
where did you find the lte apks and usc files?
