Root [MetroPCS/CDMA] Mobile network not working 4g and gps are HELP!!
i just attempted to install the validus 5.2 build (4.4.3) now my phone number is missing so is my min and my prl is 0 when i try to *228 it wont let me connect. same deal with ##662* i tried reflashing the stock tar with odin and nothing is helping.
Reason I ask is there was files to help enable the data signal and imei and mdn . now may I ask does the imei number show in the about phone area . PLEASE DONT POST THE NUMBER JUST yes or no
Now I need to see if when you press *#06# do the imei show the same as in the about phone and on back of the device . again please don't post the numbers just yes or no and you may see null
Also. i understand that for the most part but some things there arent exactly clear. any chance you could explain that post a bit simpler for me
If your on the full stock ROM without no mdn etc you may need to flash the modem for 4.1 where did you get the stock file from since your CDMA you can enter the info but the APN is wrong cause metro and T-Mobile edited
