Root [MetroPCS/CDMA] Mobile network not working 4g and gps are HELP!!
You have to have shab help you out his work is wonderful I think its a zip to flash but he can point you in the best direction. Or may have a updated modem he may have made to fix mdn and the whole nine yards. If you like I drop him a line or you can .
Shabby got the fix but keep in mind come 2015 CDMA will be getting cut from what I hear and see. You will need a GSM device to have carrier data. Not now but in the future
Dev-Host - SPCUtility.apk - The Ultimate Free File Hosting / File Sharing Service use this to get your 6 digit MSL write it down
open dialer *#22745927 and enable hidden menu
reboot the phone
open dialer and enter ##786# click on reset default
enter your MSL
This will clear your NV items, wipe your device and reboot. when you start it back up it will do a hands free activation just like when you first bought it from the store. i do this on every CDMA device i sell so that the next owner gets a fresh clean phone that doesnt need to be reprogrammed. once you get that reactivated, you can go back to flashing your hearts content out. please note that these are the dialer codes for stock metropcs rom, these also will not work on aosp based roms as aosp doesnt have the dialer codes built in.
So i just reflashed the validus rom. for some reason its not letting me see the spc in there and it reset my number again. is there any particular way to have my cake and eat it too in this situation? should i try to apply the steps above? THe difference being this time i have an nv backup.
reboot the phone
enter your MSL
as i said they are for the stock metropcs rom so they wont work on validus.
The system ui can crash will only say that a problem with gapps or maybe you need to wipe data and cache after going into ROM to play and see these messages pop up . just clear data and cache.
Glad to see you working again . also congratulate you on the new baby maybe he can talk on that very same phone when they get older .:p:D
