Root [MetroPCS/CDMA] [MOD][WIP][MB2 SecLauncher2 Modifications]
ARocker
Android Expert
Please backup your phone before flashing these!
Flash at YOUR own risk!!!
I'll be posting any modified versions of MB2 SecLauncher2 i make as i get them working properly.
MB2 SecLauncher2 Modifications are for most versions of MB2 including Metropolis Rom 1.2.0 and Metropolis Rom 1.1.0 by Shabbypenguin and [ROM]{D2mtr} Stock/Root/ODEX+DeOdex MB2 and [ROM](WIP) Number_Two AROMA MB2 by Ldrifta and perhaps more.
Available Modifications:
MB2 Seclauncher2 w scroll.
Stock launcher layout [4x4] with scrolling background/wallpaper.
Lol That's all so for now...more to come when i get them worked out.
Big thanks to Shabbypenguin, Ldrifta, and all of our devs and contributors!
Thanks to Toss3 for his great tutorial
This is their work, if you like it, Donate to and Thank them!
This is my effort, if you like it, hit the Thanks Button and Rate the Thread!
It works on my D2MTR, it should work for yours too.
I hope you enjoy it!
!!!Warning!!!
This zip will replace the folowing file:
Seclauncher2.apk
!!!Warning!!!
Flashing this will untheme Seclauncher2.apk
Do not flash a theme that includes a different Seclauncher2.apk as it will overwrite the mod.
Remove the Seclauncher2.apk from the theme before flashing, unless its included in the theme.
These Mods are for Touchwiz MB2 based Roms.
Installation Instructions:
Please backup your phone before flashing this!
-Copy Mod [Zip file] to sd card
-Boot to recovery
-Make Backup!!
-Flash Mod [wipe Cache & Dalvik Cache]
-Reboot & Enjoy
very good im tired of only having so many apps per row. so just to clearify what this does is ya know how on aosp roms we can stick more apps per row and even alot closer to the dock? well this allows more apps and we can squeeze more shortcuts in.
taken from the source's page not my images
before:
scaled.php
after:
before:
scaled.php
after:
Exactly! Cept there are no new rows yet. Just scrolling background.
I've been messing with adding more room to both the home screen and app drawer via the tut. Seems that no matter what you do, there are stock widget display issues. Musicplayer widget is the worst offender along with the Accuweatherwidget.
Stock launcher is 4x4. It looks like 4x5 works ok...but there are still widget size issues.
So what happens is that the music widget size is normally 4x1 and Accuweather widget is normally 4x2.
Changing the honescreen layout to anything other than 4x4 changes these to 3x1 for the music widget and 4x3 for the Accuweather widget and they don't support horizontal resize.
Most of what I've read states that the only honescreen layout that doesn't do this is 4x5 so I don't think ill be doing 4x6 or 5x6 or any size other than 4x5.
My current issue is that while I have a 4x5 launcher modded, it seems that Ive changed sonething and so the widgets mentioned above are 3x1 and 4x3 respectively.
Still working it out :)
