Root [MetroPCS/CDMA] Multi window capability
michel5891
I am currently running CyanogenMod 10.1 and I'm wondering whether or not there is a possibility to run multi window. If so what anyone of you please help me or point me in the right direction.
nahh I think 10.1 is based off 4.0 right? I believe you need a JB based rom.. but im not 100% sure :D not big on CM roms..
ooo..yeah maybe that's true too LOL, but with that being said.. I still think the OS version still matters.. 4.1+
it was ported to the s2, but only to a JB based rom
Cyanogen mod 10.1 is 4.2.2 I believe... So only reason it wouldn't work is because of touch wiz ...
I recently read an article which said that android-developers see multi window on CyanogenMod 10.1 as "forking". Which means; if CyanogenMod 10.1 developers were to integrate multi window into their operating system it'll be basically ripping off of touchwiz. However, I do believe that it will be a really awesome feature to have.
Halo will probably be integrated soon and that has multi window esque abilities...
or you could get Sidebar Pro its just like multiview.
e7d2pU2-6ws21rGC-0uguVFnYo21v1g-CxUNca_B6-xyx7ZjFCeXaccOwsSgFD7BUm79=h230
https://play.google.com/store/apps/...sMSwxLG51bGwsIm1vaGFtbWFkLmFkaWIuc2lkZWJhciJd
Not exactly it, it doesn't allow you to see two apps running at the same time with a split screen view.
I said like didn't say exactly the same. I assure you the link was posted for further information just incase anyone needed to know more. But thank you for your observation.
