Root [MetroPCS/CDMA] pleaseeee help!!
darryim
I downloaded the baked bean rom us cellular version
Sinse it doesn't say metro version in there well I installed it
But I wasn't getting 4g so I went back
To stock now I have 4g but I can't make
Calls or text Any help anyone??
You should have confirm the version before flashing anything, call metro to get you min and mdn so you can reprogram it.
1. In dialer enter *#22745927
2. Enable Hidden menu. Exit back to dialer
3. In dialer enter **772
4. Select Edit option in the NAM Info screen
5. Enter phone number in the MDN field.
6. Enter MIN in the MSID field.
7. Press back key. Select Done. Device will reset.
Wat do I tell dem wen I call?? Just to give me that
If they ask wat happened .. wat do I say?
Do I say I was rooted or wat do I say anybody know?
Don't tell them that you are rooted just tell them that u accepted some ota software update and it mess your phone up and follow the guide n u should be good.
I CALLED DEM and we did what you said but it didnt work i still cant call or text . :(
I fixed my self guys .. wat i did was , i just wet back and insalled the nightly ROM again den go into mobile network setings select network mode = LTE/CDMA/Evdo ,
System select = home only
CDMA subscription =nv ...now Disable data press back botton ad turn on airplane mode after reboot phone , when back on just disable airplane mode and turn data on . you shud be good now.
Glad to hear that :thumbup:
