Root [MetroPCS/CDMA] [ROM] BAM-2.0-RC1-20140113-KitKat-d2mtr.zip
Is everything working with this rom??... Camera, sms, mms, etc?? And what features does it have?..
Wanna give it a try lol
We have a thread for this ROM lol, its jelly bam but they changed the name to bam ROM..... They are working on rc2 now,so they will be a update today or tomorrow......
Some apps force close on me, specifically netflix, anyone have this problem? Or has a netflix acc and check if it's happening to them as well thanks.
works for me, try uninstalling and downloading from the play store again, if problem persist then its probably the way your apk back up was restored
yeah i think its a backup issue... but i don't know why. i backed up from another kitkat rom and i used nandroid manager.
so no way to fix this?
I downloaded off phone and installed fine (2nd attempt)
I googled my error and it said to delete the get prop lines in the script updater script Im going to dry it now. Error status 7, Im installing RC2 if that makes a difference..
update: still getting status 7 installation aborted.
its more likelyba bad app restore, even thou you Uninstalled the App there are remnants leff, you could find those remnants that are left with that sd maid app, also you can usually find the left overs at data/dalvik-cache and delete the file that has the name of the app with the.odex extention thats acting up, itsb worked for me countless times
