Root [MetroPCS/CDMA] (ROM) CyanFox 2.0.2 Official
I tried both 2.0.1 and 2.0.2 and keyboard crashes on both plus back button doesn't work either. Anyone having this issues?
They only included hangouts app with it. no stock messaging app but i can easily pull the app from another kitkat rom and replace the mms_config.xml to get mms to work
So does the latest build have the stock messaging app for mms or do I have to get it myself from another rom?
Hey, guys I would appreciate if you help me here, I am VERY stupid about all this stuff, still I managed to root the S3 to the cyanfox 2.0.1, hate metropcs for taking so long to put us up with updates, so far so good everything has worked well.
But...There was an update for 2.0.2, and I tap on it, and installed k. However, the play store app disappeared, so I go to the app info, and I see google play services, but the options for force stop and uninstall are greyed out, not possible to tap on it.
there it says this version
com.google.android.gms
version 4.1.32(978161-36)
How do I work around this?
Thank you
