LDrifta
No Stranger 2 Danger
Happy New Year!!
This is a clean (unnoficial) build of the latest du43-legacy (Dirty Unicorns 4.3 final edition) repo with cm10.2 kernel source
Special thanks to team Dirt, CM, AOKP, PA and many more!!
for more information on Dirty_Unicorns and what it is exactly, check out this link Dirty Unicorns : About
Issues/Bugs:
-bluetooth audio streaming (seems to cause different issues for different people)
this is a current issue with cm and aokp code all together, not much i can do
other than that everything works perfect and is a fun build to play around with
Installation Instruction: CWM Recomended
-download rom and gapps (from pc)
-transfer to root of your sd-card
-wipe data, cache, dalvik
-manually format system (in mounts/storage options)
-install rom, mms then gapps in that order!
-reboot and enjoy!
NOTE: do not format your data partition on accident or you will lose all saved files on internal-sd
Downloads:
Rom: DU_4.3.1_D2mtr_Unofficial
GApps: http://wiki.cyanogenmod.org/w/Gapps
Rom Details (from developer): [ROM] [Team D.I.R.T] Dirty Unicorns 4.3.1 - Flo v4.0 - xda-developers
Source: https://github.com/DU-Final/manifest
Issues/Bugs:
-reboot and enjoy!
Downloads:
