Root [MetroPCS/CDMA] [ROM]Vanilla RootBox-UN-official-MetroPCS
Status
Not open for further replies.
Thanks to my brother from another mother Puk3n for building this for the d2mtr.
Source: https://github.com/Root-Box
Mod Type: ROM Difficulty: Easy Mod Status: Nightly Mod Base: Carrier: MetroPCS
Requires Root: Yes Apply In: CWM Recovery Optional: Optional: Android Version: 4.2.2 (JB)
the developer for Vanilla Rootbox is Bajee11
credits go to him and the development team
picture.php
picture.php
picture.php
picture.php
Description
Vanilla RootBox is built straight from RootBox sources and always carries a very light installation with no extra/useless apps. This means, you can enjoy a pure Android experience combined with AOKP/CM/PA features. Every RootBox releases are stable and always up to the challenge for a daily usage. If you're wondering how this ROM differs from any other AOKP roms out there, I only have one thing to say: Try it yourself and choose the one that meets your requirements.
Features -for a complete list : click me
Built from RootBox Sources
AOKP Features
CM Profiles
Per App DPI
Per App Tablet UI
Per App Language
Navigation Bar Colour
Camera: Save to external memory
Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting)
Phone: Noise Suppression
MMS: Fully Customizable
MMS Theme
MMS: Soft Keyboard Type (Emoji, Enter to Send, Enter for a New Line)
Home button call answer (Accessibility Option)
Variable size pattern lockscreen
RootBox Settings
Pie (Paranoid Android)
LCD Density Changer
Low Battery Warning (Pop-up & Sound, Pop-up only, Sound only, Off)
Option to control cursor in text fields using volume keys
Disable Fullscreen Keyboard (Landscape mode)
Expanded Desktop
Hold Back to Kill
CRT Animation (Screen On/Screen Off)
Lockscreen Shortcuts (Paranoid)
Lockscreen Targets (CM)
Screen Security Features (Unlock options: Quick Unlock, Delay Screen Lock, Menu Unlock, Home Unlock)
cLock (Chronus)
Option to disable sound when adjusting volume
Launch Music app on Headset connection
Hardware Keys Remapping
Lockscreen Hardware Keys Remapping
kernel update to 3.4.37
paranoid android settings
Built using GCC version 4.7 -from google
Aliasing fixes from linaro
networking optimizations
fix memory leaking
Update translation
Update Adreno driver
Fix composition issues when framework rebooted in suspend
don't clear wallpaper when SystemUI disconnects.
Carbon power
PhabletUI NavBar in landscape
Bring some Swagger Back
Add LongClick to FastCharge Toggle
Moar style fixes
Fix touch issue using 0% navbar
fix stuck pixel on screen redraw
Menu UI Overflow Toggle
Set ringtone mode even if ringer is silent
RootBox SquareMod Battery
fix mobile data usage display for sim-less devices
Enable car dock
pie on lockscreen if lockscreen is secure
Allow USB notification to show when primary SD allows UMS and MTP
*optimized apps
**lots of added language translations
------- 04/22-----
updated CM drivers
Aokp Ribbon
removed duplicate Rom control settings
------------------05/08---------------
Backuptool merged to RootBox. You will no longer require to flash gapps after flashing a RootBox update
RootBox
Man hold up our s3 is getting much love, I flash the d2usc last night and loved it but mms wasn't working so now here is our version...:D
Thanks for the ROMs! But I have one problem with this one..this FC keeps appearing
Your not the only 1, I had a few others in my group having FC's, but would be best to go to their Google+ page and post the screenshot like you did here.
But try out slim rom, it's running flawless. :smokingsomb:
I'm trying this ROM out as well as slim but for this ROM I keep getting contact FC and it say aprocces failed something like that :/
now now nutty does this mean your taking your gs3 back from your wife? hahah let her play with the note 2 for a while.
can i use the weather apk from TW rom on this rom have to have my weather widget.LOL
Lol nothing from TW will work on aosp. I've found that lockscreen weather widgets are std on aosp. But for your home screen I recommend fancy widgets
Status
