Root [MetroPCS/CDMA] Swapping external sd
apeiiron
I'd like to replace the 16 I have for a 32. I'm a little concerned about losing my backupsso I wanted to double check. All I need to do is copy and paste the entire contents from one to the other correct?
It would be a lot easier to use your PC and a card reader. Copy to a folder on the PC and then copy back to the new card, this will also give you a backup on the PC.
