What are some roms that use touchwiz and have/support multi view(window). I really just want to be able to use multi view. Im really diggin CM10.1 and blackbean but again i want to be able to use multi view . Can anyone help?
Just know that battery life isn't the best on them... but not the worst either.
Battery life is actually pretty good if you set it right
what do u think the best settings are ? ( for max batt life)
