ARocker
Android Expert
Whenever I have WiFi connected and I reboot the phone, it always starts up showing WiFi is on but it doesn't scan or see any wireless signals, even though it shows its on (in both notification toggles and in system settings show WiFi is on).
Turning WiFi off/on again from the notification toggles does not work even though it shows it is. Going into system settings and turning WiFi on that way works and it connects normally after that, until I reboot again and the process repeats.
I had been running BB final but last nite I flashed king kang to check it out and ran into the same WiFi issue after reboot.
After that I went back to stock rooted and found I could reboot and WiFi reconnected properly every time.
I'm back on a fresh download and install of BB and the wifi issue is back. I'm living with the issue as Its really just an annoyance and I really like BB best.
Any ideas or help would be appreciated.
Thanks much.
Thanks much.
