every time I go in twrp to flash something I put the file on my phone and I go into recovery and it doesn't show up.. I have no clue why.. any suggestions? Thanks in advance
If you put it in the root of SD (not in any folder) you should be able to find the zip file near bottom of the list in twrp if its anything like CWM
yea its a small bug that happens when ur into flashing lots of roms. first theres the usual case with the 0 folders i flashed so many roms just testing for shabby that i had them like this 0/0/0/0 so if u do find a zero folder take everything important to u from that and move it outside of the 0 folder then delete it. also new 2.5.0.0 twrp has a toggle to switch from internal to external to otg usb just hit the tab up top change the location of where u want to search and it you should be ok.
Hmm do you happen to have the link to the 2.5.0twrp
thanks a lot! even with this version still appearing files ive deleted and not the ones there. like for instant I'm trying to flash the deviantrom but In twrp it's still showing goodness rom fromapawhile ago when I flashed that rom
Nasty I just deleted the whole 0 folder, but now it says I have 6.47gb free space but nothing is there :S
