Root [MetroPCS/GSM] CM12 5.0.2
Guys I found a lollipop rom that works on my metro T999.
Here is the link:
http://trueandroid.com/install-andr...-galaxy-s3-sgh-t999-via-cyanide-l-unofficial/
Do the usual.... Backup first. Then clear everything and install the rom , gapps 5.0.
When you boot the first time you may get stock; take out the battery and reboot and it will boot fine this time. All you have to do after is disable the stock keyboard and camera and install your own. (Open Camera) from the market works ok. Then go to apn setting and select the metro pcs one.
Let me know if anything.
