Gman9831
I'm no Senior
MetroPCS Guide/FAQ
Index: Metro GSM/BYOD
1. APN
2. Bands/Phone Compatibility
3. Coverage
4. IMEI
5. SIM Cards
Metro CDMA
1. CDMA Shutdown
Metro GSM/BYOD
1. APNs: How to access APN settings on most phones? Go to Settings > Wireless & Network > Mobile Networks > Access Point Names
Below is the standard APN for MetroPCS GSM
apn carrier="MetroPCS LTE
mcc="310"
mnc="260"
extraid="6D"
apn="fast.metropcs.com"
user=""
password=""
authtype="0"
server=""
proxy=""
port=""
mmsc="http://metropcs.mmsmvno.com/mms/wapenc"
mmsproxy=""
mmsport=""
type="default,mms,supl"
preferapp=""
The T-Mobile one which is below is also known to work
apn carrier="T-Mobile LTE
mcc="310"
mnc="260"
extraid="6D"
apn="fast.t-mobile.com"
user=""
password=""
authtype="0"
server=""
proxy=""
port=""
mmsc=" http://mms.msg.eng.t-mobile.com/mms/wapenc "
mmsproxy=""
mmsport=""
preferapp=""
Bands used for Metro GSM:
GSM- 1900MHz
HSPA- 1700/2100MHz or 1900MHZ. 1700/2100 has the larger coverage area at this point. But all further HSPA expansion is in 1900.
LTE- (AWS)1700/2100MHz
Later in the year of 2014 they will start using PCS and 700MHz B12 for LTE
B2 = Band 2 = 1.9GHZ = 1900MHz = PCS
B4 = Band 4 = 1.7/2.1GHz = 1700/2100MHz = AWS. They all mean the same. Most times B4 may just be listed as 1700MHz but if its listed as 2100 that is not the same thing.
Phone Compatibility FAQ: What phones can be used on BYOD? Any unlocked GSM phone. The only band absolutely necessary is GSM 1900MHz. But with that you only get 2G.
Can T-Mobile branded phones be used without it being unlocked? Yes
Will I get LTE? If the device has the bands compatible for LTE and those are the bands used in your area.
Is this the same thing as flashing? No. This is a different technology and MetroFLASH was discontinued anyway.
Any further BYOD compatibility questions can be asked: http://androidforums.com/metro-pcs/738676-official-metropcs-byod-discussion-thread.html
3. Coverage: For Metro GSM coverage map https://www.metropcs.com/content/metro/en/desktop/metro/coverage.html
4. IMEI
To check for bad IMEI you can use: Unsupported Browser
If my phone has a bad IMEI from AT&T or any other US carrier will it work with BYOD? No, T-Mobile and all US carriers share blacklists.
5. SIM Cards/Activation: How much is a MetroPCS BYOD SIM ? $10
Can be bought online here: http://www.metropcs.com/metro/categ...simcard/detail/MetroPCS_SIM_Card/610214633514
Activation Fee: The standard activation fee is $15 in store. But it is free online here http://www.metropcs.com/metro/activation/activation.jsp or over the phone 1-888-8metro8
Metro CDMA
CDMA Shutdown: MetroPCS's CDMA network was officially shutdown June 21st 2015
