Root [MetroPCS] Help please !!!!
KT32
PLEASE HELP !!!: I currently rooted my phone and a week later my phone isnt working. What i mean by not working is i cannot power my phone on without removing the battery a re-inserting it. It will power on when the battery is inserted and the LG logo will come on. The LED around the home button will do its color show cycle beginning from the color red. It will cycle through to the color red three times and on the third time the phone completely shuts off and i cannot boot it back up using the power button. It happens so fast, i cant boot it into the TEAMWIN recovery that i am using. Can someone please help me. I would usually know what to do but i have no idea what is going on.
Is there anything that did or changed on your F6 before this started happening?
You're rooted and have TWRP installed... Do you have a nandroid backup saved on the device?
Have you tried booting into recovery by -
Make sure the phone is fully charged
Removing the battery from the device and then wait about 10 -15 seconds and then reinstall the battery and then press power button,
Press on rhe back arrow button (←) and the settings menu button (≡) at the same time continuously until the recovery menu screen flashes, if it flashes the recovery menu screen, Press the volume down (-) button and hopefully you'll be able to fully boot into TWRP recovery and then just restore your nandroid backup and you should be back in business!
Thread moved to the LG Optimus F6 - All Things Root Forum. To better assist in help and exposure from fellow F6 users and topic of discussion is about a rooted device.
Thank you so much. I found out the problem and it was the ROM. I used a different one and everything is running smoothly and it's back to normal.
That issue has to be due to something else other than the rom. Most of the roms available for the f6 boot up with no problem. Even the beta roms boot up just fine.
You shouldn't have a bootup problem with any of the following roms...
  • KK port
  • CM11
  • Dana
  • Xperion
Maybe you got a bad download or the zip didn't flash properly.
