Mattswad
Member
so I hear a lot of people mentioning they use foxfi as a source of USB tethering and as far as I know is the only source that works for tethering. However when I use it I get dreadfully slow speeds not even comparable to the speeds I achieve with only the phone itself.I am using hide tethering level 1 and have tried using the Google DNS and without it.I am not sure of the exact build installed on my cpu as Im away from it now but my Phone has Foxfi v 2.15.2 with full version unlocked. but I have tried them all.
am I doing something wrong or am I missing something obvious or am I just stuck with dreadfully slow internet speeds and the ability to log on 2 only certain sites?
or is there a build prop tweak or some type of setting that I can manipulate to get full speed internet through USB tethering? Also is there another way to get wifi tethering other than what was mentioned in the posts here earlier? As I success with that method works but somehow I have never been able to obtain it again despite a factory reset and data wipe. Forgive me if I am asking questions that are against forum guidelinesI hope that I am NOT causing problems with this post.but if the nature of your response is questionable please feel free to email me at mattswad@gmail.com
Thank you in advance!
Op sys: Win 7
Op sys: Win 7
