They raised the $40 plan from 500MB to 1GB and the $50 from 2.5GB to 3GB.
https://www.metropcs.com/plan.html
And to keep people from migrating to AT&T (Cricket).
Boost Mobile also just released a temporary offer to double the data on their plans. They're all really trying to compete with each other to keep/gain customers.
Your plan well be updated automatically. I checked my plan and I was already upgraded.Will we get that automatically, or do we have to switch plans? Back before the smartphone days, I remember Metro improving a plan but making it a different plan code so you had to switch plans to get the new features. All that even though the price was exactly the same.
Think I will stick with my LG Volt with VM. No matter what plan you are on you get unlimited data.
Course after the first 2.5GB they will throttle you. But it's still unlimited.![]()
Anybody in the St. Louis area using metropcs? If so, how is it working for you?
HA! Even with only 250 megs of data I'll NOT relenquish my $30 per month plan until the bitter end sir!another tactic to pry people's CDMA handsets out of their cold cheap hands.
A great antic for those that already have a GSM device.another tactic to pry people's CDMA handsets out of their cold cheap hands.
