Root [MetroPCS] lg f6 working led
emofox
Member
is there a way to get the led light working on the lg f6 with carbon ROM and the cam-fix kernel installed?
Follow the intructions in this thread on how to enable notification led lights: http://androidforums.com/threads/se...-and-sd-card-hack-with-working-camera.901824/
(If its the back camera led light then there is no fix for that as of now)
It gives you everything you need to get the most out of the carbon ROM. You will need to know how to use xposed installer which is really easy. I'm actually following the steps to install it on my F6 right now lol.
when i use gravity box it only flashes the led for the navigation buttons, im looking for a fix for the notification light around the center button that changes colors.
From what i know there is no way to get the notification light working it has not worked on any version of KK that any of the dev's have been working on. Please note that I may be wrong about no way of getting it to work but if you read through all the posts and everyone and there mother has asked about this. But carbon Rom is a great rom just has a few bugs and I know DM47021 has been working to get everything working on this rom. I ran it for a while and it a great ROM as for me I have moved on and no longer have a F6 and moved on to a Google Nexus..
From what I've read on this forum, the reason why the LED was disabled is because it would constantly strobe whenever you would use it. So hroark13 just disabled it.
